I am somewhat new to ACA so please be forgiving ...
I've got a wall style that has multiple components. I have changed one component so the bottom starts 12" below the baseline ht of the wall.
The section window display reflects the change, but the wall style won't update.
Is there a setting I'm missiong somewhere.
Solved by KathyMoffa. Go to Solution.
Even though you indicate in the wall style that a component is to start below the baseline, you still have to manually project it down. Right click your wall, select Roof/Floor line, select Floor and Offset -12. If all your components project down, not just the one component, make certain that the other components' Bottom Elevation is set at Baseline, not Wall Bottom.
That's it. thanks Kathy
Seems like it should do it automatically, though
