Im using autocad arch 2011.
i have buildings that are xrefed from a complex plan into a floorplan drawing and im xcliping the xrefs to show certain areas. Most of all the xclips have the walls cleaning up except for a few, but if i just move that xclip over a few feet then the walls clean up, but if i move it back to the orginal location the walls wont clean up.
i have the wall cleanup between host and xref drawings checked,
thank you
Solved by David_W_Koch. Go to Solution.
