AutoCAD Architecture General Discussion
Valued Contributor
VaDesigner10
Message 1 of 5 (530 Views)
Wainscot
530 Views, 4 Replies
01-24-2011 08:01 PM
What woudl be the easiest/most common sense way to add wainscot to a room in CAD?  If it is paneling, should it be a block, or added to the wall as a component?
Valued Contributor
JustoAg
Message 2 of 5 (481 Views)
Re: Wainscot
01-26-2011 07:55 AM in reply to: VaDesigner10
what I do is add a Mass Element with its correspondent geometry to the face of the walls that need it. It easier than creating a new component to a new wall style. This has the advantage of setting the proper material to the wainscot commonly different from the wall material. And, besides, you gain control of its area apart from the wall itself at the schedulling time.
Just a point of view, could be others.
Justo Aguiar.
Contributor bec
bec
Message 3 of 5 (477 Views)
Re: Wainscot
01-26-2011 08:30 AM in reply to: JustoAg
I am assuming you are doing this for 3d only, so I would add as a comp to the wall...  You can still change the material in MAX and you wouldnt have to model it then add.  But the other way is easy too... Take your pick...  :-)
Distinguished Contributor
noahma
Message 4 of 5 (415 Views)
Re: Wainscot
02-01-2011 11:07 PM in reply to: VaDesigner10
the easiest way I have found to do stuff like this is to create a wall style that is as thick as the wainscoting. Then for the top and bottom add a sweep for the trim to it.  It works GREAT! its quick, easy, and can run anywhere and everywhere you need it.
Distinguished Mentor
ntellery
Message 5 of 5 (381 Views)
Re: Wainscot
02-05-2011 07:32 AM in reply to: noahma
I agree with the wall style idea.  It cleans up with itself, you can mitre it easily when attaching a sweep.
You can attach as a componant in the exisitng wall style but I found it a lttle tricky if you want to have separate control from the wall.  Just add a new one  with a different cleanup group.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://www.youtube.com/playlist?list=PLD9BF5D8FF70CD3DF&feature=view_all
