Actually Autodesk does have a work around. Contact Autodesk Subscription
Support.
Dear Tom,
Attached you will find the files necessary to install your product in
a 64 bit environment.
Please follow the below installation instructions:
1.. Install the latest .NET Framework (64 bit) from Microsoft on the
destination workstations.
2.. Copy the contents of the installation DVD to a local drive or
network location.
3.. In the main install folder, rename the original MEP.msi and
setup.ini files to preserve them.
4.. Copy the provided replacement MEP.msi and Setup.ini files into
the main install folder.
5.. Run the installation/deployment procedure as normal.
Our development team is working on a true 64 bit application but
cannot provide any further details at this time.
Please let me know if you have any questions about this information
and I will be happy to address them.
Best Regards,
Kathryn Poulos
Autodesk Support Team
"Dean Saadallah" wrote in message
news:5656307@discussion.autodesk.com...
you don't, not written for it, read all about it here by using the
search feature.
Dean
