I am a new student to Autocad Architect using version 2013 and am doing the 2010 tutorial (apparently the latest available in the Autocad Architect support section) to find my way around. I am looking for a way to keep the tutorial PDF open and readable on the screen while following the tutorial instructions to do operations on the Architect 2013 program. Whenever I do any selection or operation on the Architect program the tutorial automatically minimizes and disappears off the screen at first touch in the Architect program. This makes it more difficult to follow lengthy instructions involving a sequence of selections and button clicks because the tutorial has to be redisplayed so often instead of just being there to refer to constantly. How can I keep the tutorial displayed while working in the Archirect program?
Dual-screen perhaps, if your current screen isn't wide enough to dock both program windows side by side.
If you are using a PDF tutorial, that is probably opened in Adobe Reader which is as you know a separate software application. Same as having a Word or Excel application open together with Autocad. Click on the Word document and Autocad will minimize and vise versa.
If you use the tutorials through the Autodesk Exchange (top r/h corner of autocad screen) that window will stay open same as the autocad help window.
The installation of the AutoCAD Tutorial Document CHM file into the AutoCAD Architect Help file does not complete. A selection for this file does not show up in the Help dropdown in the Architect program. I have tried installing on two different paths into the Help files and neither works. I am using windows 7 and AutoCAD Architect 2013. The two paths are: (1) C:\Autodesk\AutoCAD_Architecture_Help_2013_English_Win_64_32bit and (2) C:\Program Files\Autodesk\AutoCAD ACA 2013 Help\English\Help. Nothing happens with either install. I then tried downloading and installing the AutoCAD Architecture 2013 OFFLINE HELP per the readme files for this download. I thought this might be required to get the Tutorial Document to install on the HELP drop down list. It downloaded fine but when I installed it this program hung up. The file is called autocad_architect_help_2013_english_win_64_32bit. It successfully goes thru RUN,thru the INSTALLER with progress showing to completion, then the AutoCAD install window and the license agreement window but then hangs up at the INSTALL>CONFIGURE INSTALLATION window. At that point everything is grayed out except the BACK and CANCEL buttons with no further explanations. I tried cancel and a pane showed it to be running so I let it run overnioght. This morning it was still there just the same. I canceled and retried with all the same results. I am blocked from further progress on this effort as well as getting the CHM Tutorial file to install in HELP.
