Argh. I should have just left well enough alone.
I have a Logitech MX 600 cordless mouse. I just updated the SetPoint software as I got a new cordless keyboard. Now, the middle button pan is erratically working. None of the settings has changed. MBUTTONPAN is set to 1. Middle button is still set to "Middle Button."
Sometimes the pan works. Most of the time it doesn't. Anyone know if there are new setting on the SetPoint software I need to check or uncheck? I've even tried messing with some CUI settings under the mouse component...
Figures. After spending 45 minutes on this problem, the second I post to the forum, I've found a "work around." In the rare case someone else might have this problem:
I have the type of mouse that you can mavuever the middle wheel to the left or right in addition to pressing down on it. So, I set the left and right scroll functions to "unassigned" and left the middle wheel function to "middle wheel." Seems to work like a charm. It must be that sensitive that I was getting some interference, so to speak. Strange that I didn't have this problem before I updated the software. Jeez.
I use a logitech wireless keyboard mouse combo and as you have found, get things reset every time SetPoint is updated. I have even had instances where things get reset even without updating the software. I have found that you can backup your settings. Just copy the user.xml file from the logitech directory and save it in a safe place:
(this is for WindowsXP, don't know where it would be under Vista/Win7)
C:\Documents and Settings\your_user_name\Application Data\Logitech\SetPoint\
Next time you update Setpoint or things reset by itself, just copy the user.xml file back in there to get your original settings back.
Try setting your thumb button as middle mouse button and use that for pan. This way you can still use the mousewheel tilt for some other function like back and forward in your web browser. Ever since I have a thumb button I use that to pan and I think it is much better then the mouse wheel.
