Solved by David_W_Koch. Go to Solution.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<sgt_addyjp> wrote in messageI'm
href="news:6039449@discussion.autodesk.com">news:6039449@discussion.autodesk.com...
getting this msg and I don't know what it means. Never seen it before.....
"the properties of these layers should be evaluated to ensure they display as
intended in paper space viewports and in layer states. view the list of
unreconciled new layers in the layer properties manager" DO ANYONE KNOW WHAT
THIS MEAN?
I'm also getting this message when I print.
I do see in the layer manager that there is a list of unreconcilable layers but what exactly does this mean? I don't really care that I have them. I just want the error message to stop popping up when I go to print.
After I put in the "Layereval" comand. It says to "Enter new vlue for Layereval <1>: "
Any input would be great.
Thanks.
The layer evaluation feature is meant to provide a warning that new layers have been added to a drawing, either by attaching an external reference (or reloading the reference, and layers not present previously are there now) or by inserting a block reference from an external source. The presumption is that you have set the drawing up, with the desired layer settings, and now new layers have been added, which should be reviewed to verify that the settings are appropriate before plotting and possibly wasting a plot because of incorrect layer settings. If this sort of warning appeals to you, you can leave it active. All you need do what you get the warning is open the Layer Properties Manager and look at the new layers (there will be a filter for unreconcilled layers). You can select all that pass muster and reconcile them and make whatever settings adjustments are needed on the rest.
If you have strong layer standards in place, and effective ways of implementing them, and therefore find the warnings annoying and would rather not have to take the time to reconcile the layers, you can set the values of several system variables to turn off the feature or limit the feature:
LAYEREVALCTL can be set to 0 (turns off evaluation and notification of new layers) or 1 (turns on evalutation of new layers, based on setting of LAYEREVAL). This is saved to the user profile, affecting all drawings opened under that profile.
LAYEREVAL controls whether layers are evaluated, and has three possible settings: 0 (off; no evalutation), 1 (detects when new external reference layers have been added in the drawing), or 2 (detects when new layers have been added in the drawing and in external references in the drawing). This is stored in the drawing. If LAYEREVALCTL is set to 0, the setting of LAYEREVAL is ignored.
LAYERNOTIFY controls when notification alerts are displayed. This is a bit-coded variable; each of the possible notifications is assigned to a particular bit, and if that bit is set, then that notification is active. In other words, the value of LAYERNOTIFY is the sum of the active bit values. This is stored in the drawing. If LAYEREVALCTL is set to 0, the setting of LAYEREVAL is ignored.
0 - Off.
1 - Notification given when plotting.
2 - Notification given when opening.
4 - Notification given when loading/reloading/attaching external references.
8 - Notification given when restoring a layer state.
16 - Notification given when saving.
32 - Notification given when using the INSERT command.
