AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
unknown Textstyles appearing in file
5 REPLIES 5
leah.smith
377 Views, 5 Replies
Having an issue with my file. I created a new mtext leader and it is set to one scale of 1/4" it shows fine in model space and paper space. Then when edit my drawings to try to add hatch or dim. there is a large text that appears in the back ground. If anyone can help that would be appriciated. Thank you!
5 REPLIES 5
pendean
in reply to: leah.smith
Perhaps you just need to turn off ANNOALLVISIBLE variable (describe in HELP) or explore ANNORESET if the issue is the other scales of the text are no where near the scale you have active.
leah.smith
in reply to: pendean
I attempted both and it is still showing in the back ground. I can only see it when I go to add a hatch to the drawing and I have deleted the text and added the notes back to the drawing.
pendean
Are there other layers that are off but have text in them at these locatons?
leah.smith
no I checked that, all layers are on. Smiley Sad
zalant
How about setting SELECTIONANNODISPLAY to 0? Does that clear it up?
If not, please post a sample drawing here and I can check it out for you.
Zac Travis
”Boost
