Having an issue with my file. I created a new mtext leader and it is set to one scale of 1/4" it shows fine in model space and paper space. Then when edit my drawings to try to add hatch or dim. there is a large text that appears in the back ground. If anyone can help that would be appriciated. Thank you!
I attempted both and it is still showing in the back ground. I can only see it when I go to add a hatch to the drawing and I have deleted the text and added the notes back to the drawing.
How about setting SELECTIONANNODISPLAY to 0? Does that clear it up?
If not, please post a sample drawing here and I can check it out for you.
