I just installed autocad architecture 2012. when i opened it to start creating a new drawing/project the unit of measurement was in Millimeters.. i needed the Unit of measurement to be in architectural units, so i used the units command to change it to architectural units. the problem i am having now is that i think the Grid Scale is still in MM. when i tried to draw a line on the grid the line appeared to be tiny. the length of the line was 36'-5". i adjusted the scale to 1/4"=1' but that didnt change anything. in order to see the line that i drew i have to zoom in so much..
How do i adjust the grid scale to be the same as the units?
MEASUREMENT command, not UNITS command, to change a file format between metric and imperial.
