AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Unable to lock irregular View Ports
5 REPLIES 5
base1000
346 Views, 5 Replies
I am unable to lock irregularly shaped view ports, also my right click does not work for locking any view ports. It works on older versions of AutoCAD.
5 REPLIES 5
in reply to: base1000
Does not work?
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
Select the viewport and either on the properties palette set it to lock
or on the status bar to the right of "VP Scale" click on the padlock icon
to lock or unlock the viewport
Leo
wrote in message news:5829934@discussion.autodesk.com...
was the viewport clipped?? if so then use the VPclip command again and
select the viewport and then it will ask you to for polygon or delete select
delete..... then remake the viewport.... but I think you might have a
viewport on top of a viewport.
"Leo the Builder" wrote in message
news:5830329@discussion.autodesk.com...
Leo
To all - Especially base1000,
When you have an irregular viewport, AutoCAD creates a polyline that is uses
as the clipping object and it is grouped with the viewport. If you select
that irregular viewport and check the properties palette, you will find that
TWO objects are selected! This automatic grouping and selection makes the
RC default to a generic menu and the status bar lock unavailable. You have
to access the display lock through properties... select the viewport, choose
the dropdown at the top of properties to select only the viewport
properties, and set the display lock.
HTH,
Larry Bettes
ACA (ADT), C3D (& LDT/CD)
(06, 07, & 08 with all SPs installed)
P4 - Dual Core 3.0 GHz, 3.00 GB RAM
nVidia GeForce 6800 GS AGP - 256 MB
Windows XP Pro, SP 2
base1000
Irregular means it is not a square viewport. If I use this kind of viewport I can not lock it in any way, also I do not have two viewports on top of each other. Also no one has answered why my right mouse button does not work to lock viewports, the older versions of AutoCAD worked just fine regarding this.
”Boost
