ACA 2008
I copied the steel, u-shaped, 1/2 landing stairs from the stair styles
drawing in the styles directory. I've changed the height & number of risers,
width etc.no problem.
What I'm having trouble with is trying to eliminate a riser or two on the
bottom flight and add them to the top flight. When I grab the grip called
Flight Start all it lets me do is rotate the entire stair. I'm sure this is
easy and I'm just missing something...
Scott.
