AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AutoCAD Architecture 2008 - Apparent intersection not trimming
8 REPLIES 8
Message 1 of 9
dficarra
9910 Views, 8 Replies
I'm using ACA 2008 and used to be able to pick two lines that didn't physically cross each other and use the trim command to trim them based on where they would cross if they extended to each other.  But it doesn't seem to do it anymore.
Best way I can describe it is it used to trim at the apparent interestion of where they would come to gether.  I'm sure there's some easy fix to this, just don't know where it's at.
Can anyone help?
Thanks!
@dficarra for clarity Kevin.Palmer edited the original subject: Trim lines of "apparent" intersection???
8 REPLIES 8
Message 2 of 9
leothebuilder
in reply to: dficarra
Set variable: Edgemode = 1
Message 3 of 9
dficarra
in reply to: leothebuilder
I love the easy fixes, worked fine.  Thanks Leo!
Message 4 of 9
Seychellian
Didn't work for me 😞
Message 5 of 9
pendean
in reply to: Seychellian
What part?
Post a DWG portion with the problem, point to what you tried and with what objects in the file, let's all text it for ourselves.
Message 6 of 9
Seychellian
in reply to: pendean
@pendean wrote:
What part?
Hi Sorry for the ridiculously delayed response. apparently i didn't subscribe to the thread. See attached file.
Message 7 of 9
David_W_Koch
Your two lines are not co-planar.  TRIM will not work on them.  You can grip edit the endpoint of the line to be trimmed and use the Apparent Intersection object snap override to get the endpoint of that line to move to the apparent intersection of the two lines.2017-11-04_TrimLines_Seychellian.png
4
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 8 of 9
jmoir
in reply to: David_W_Koch
Try to change Command: EDGEMODE from 0 to 1 this will work!!!
same when you like to extend aparent but not touching lines.
EDGEMODE=1
Message 9 of 9
rameshpatel74
i want trim 3dpoly using lips after trim last vertex marge on crossing 3dpoly Re: how trim to apparent intersection between two 3dpoly
”Boost
