Sorry , didn't read carefully enough.
Early morning here!
"Nathan" wrote in message
news:6246971@discussion.autodesk.com...
just a thought - have you ticked search blocks as well as xref's in the
schedule properties?
wrote in message news:6246917@discussion.autodesk.com...
drawing #1 (xref) - floor plan with blocks for doors (drawn by others) and
i've added a property set that applies to blocks to all of the door
instances. no problem. drawing #2 (sheet) i created a schedule table based
on the property set definition that i created in the xref. no problem.
when i create the schedule (don't select any objects because i want to
schedule the external drawing #1) it's fine, when i change the field to
select an external drawing, then i select the file.....i get nothing. i
update the table and i still get nothing. i copy and paste the schedule
into the xref itself and i'm able to schedule the doors no problem. if i
copy a door into the sheet i can schedule that. i have no unresolved xrefs
in xref or the sheet. i have no filters (just a "*" in that field under the
schedule properties.) i'm stumped. the table is set to apply to block
references. the property set applies to block references (i wouldn't have
been able to create the table style otherwise.) what am i missing? i've
tried setting the filter to *|a-door and *door just to see if it would
trigger something (all of the blocks are on a-door in the xref - i confirmed
that.)
any helpful ideas would be greatly appreciated. thanks.
