Here's how I was instructed to create my 'master' tool palette:
1. Create a 'Master Project Template'...
2. Create a new drawing and call it MASTER STYLE.DWG. In this drawing I will
bring in all my wall styles, door styles, window styles, etc.
3. Create a new Tool Palette in my Master Project Template, based on my
Master Style.dwg. Then, whenever a new project is started using my master
project template, the tool palette comes along with it. But it doesn't get
updated.
From reading these posts, I'm gathering that what I needed to do was to
create a Tool Catalog Library from which a tool palette is made and linked.
Is that correct? If so, is there a way to create a catalog using the tool
palette I've already poured a bunch of time into? Or does this work some
other way?
Scott.
wrote in message news:5837506@discussion.autodesk.com...
How did you get the tool palette you have into your workspace initially?
Did you create it yourself, or did you bring it in through the Content
Browser?
i-dropping is just a fancy name for the process of dragging and dropping a
palette, package or tool from Content Browser into your drawing or local
workspace. It can also be used to download content over the Internet. When
you hover over the link in Content Browser, your cursor should change into a
"empty eyedropper". When you left click and hold on the link, the
eyedropper will "fill up" with the content, at which point you can drag the
cursor over your drawing or over the tool palettes and drop.
If, as previously mentioned, the catalog from which the content was obtained
is set to have its content remain linked, then you should get a refresh icon
at the bottom of your tool palettes, on the corner away from the "spine".
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
