I am creating new tool palettes for lab equipment blocks. I was able to create a new palette and drag and drop blocks into it. When I go to create other palettes I am unable to drag and drop blocks into them. I am able to drag and drop into the tool palette I previously created and then drag and drop into the new palette. But when I shut off Autocad and ropen the new palettes disappear. How can I create a new tool palette and it works, then create other tool palettes and I can not drag and drop to it? I am using Autocad Architecture 2013. Thanks in advance.
Kory Skoog
CADD Technician
Is this a new installation of AutoCAD, or have you had it for a while, and this just started happening?
Please let us know what steps you're following.
If you'd like to insert/attach screen captures, that would be great.
Sorry for the really late reply. Here are the steps
1) Right click on tool palette and select "New Palette".
2) Rename palette.
3) Select block, from saved drawing file, to show grips. Drag, by holding down the left mouse button, to tool palette and shows as the attached image. (Black line on top of palette to show where it will be inserted).
4) Release left mouse button and nothing happens.
This is a new computer. I was able to create new palettes earlier with this computer and version of Architecture 2013. I also instaled service pack for Architecture 2013.
Kory
