AutoCAD Architecture General Discussion
Valued Contributor
dwi_it
Message 1 of 9 (3,086 Views)
The tool cannot be found in the current workspace
3086 Views, 8 Replies
08-19-2010 01:41 PM
I am recieving the error " the tool cannot be found in the current workspace" when clicking on the elevation callout tool under the annotate ribbon. How do I go about troubleshooting this issue?
David_W._Koch
Message 2 of 9 (3,083 Views)
Re: The tool cannot be found in the current workspace
08-19-2010 04:37 PM in reply to: dwi_it
Certain content-related ribbon tools work by running a referenced tool palette tool.  The out-of-the-box ribbon tools that do so reference a tool palette that should have been included in your workspace on installation, but which is not assigned to any tool palette group (other than the All Palettes group, of course).  You may fine the following blog article of interest:
http://architects-desktop.blogspot.com/2009/06/autocad-architecture-2010-ui-changes.html
If you want to know more about how these work, I wrote an AU Tech Talk article about how to create a Ribbon Tool in December of 2009.  You can find a link to that article here:
http://architects-desktop.blogspot.com/2009/12/aec-content-on-ribbon-au-tech-talk.html
David Koch
Active Member
mtrblt
Message 3 of 9 (2,599 Views)
05-04-2011 02:50 PM in reply to: dwi_it
same problem
in the annotaction ribbon all the tools w/in these panels:
scheduling
callouts
keynoting
brings up:
annoying
Active Member
mtrblt
Message 4 of 9 (2,583 Views)
05-04-2011 05:17 PM in reply to: mtrblt
should also add that the problem is in both 2011 & 2012...
Valued Contributor
dwi_it
Message 5 of 9 (2,578 Views)
05-05-2011 04:46 AM in reply to: mtrblt
We eventually solved this with a total uninstall / reinstall of AutoCAD. Still not sure of what caused the problem.
New Member
DMulveyThermmax
Message 6 of 9 (2,576 Views)
05-05-2011 04:56 AM in reply to: dwi_it
ive tried the uninstall and reinstall and it didnt work
Active Member
mtrblt
Message 7 of 9 (2,543 Views)
05-11-2011 05:02 PM in reply to: dwi_it
reinstall worked on both 2011 & 2012.  thanks for the tip.
i used the autodesk reinstaller so it wasn't a hassle...just a bit of a wait.
jbernier
Message 8 of 9 (451 Views)
07-09-2014 07:28 AM in reply to: mtrblt
Dear Autodesk,
Thank you for making previous versions of your product still work after upgrading. Fortunately I am still able to meet my deadline by using obsolete, yet functioning software, instead of the expensive upgrade that doesn't work.
Brilliant plan!
Member
leonlo13
Message 9 of 9 (37 Views)
12-10-2014 05:45 AM in reply to: dwi_it
When clicking on a tool from the ribbon or the tool palette you get an error that states: Tool not found: The tool cannot be found in the current workspace. But when you check your workspace you are set to the correct one.
Tool cannot be found
When you get this message check to see if you are using the global profile or Architectural. Chances are you are using the Global profile which will give off this error for most of the tools and the tool palette as well.
This can be changed by closing the software and starting from the desktop icon with Metric or Imperial in the title. This can also be achieved by changing the profile within the Options dialog box > Profile tab and set imperial or metric to current.
