I need some help with this. In the attached sample. I am linking T.O.C. EL. and T.O.S. EL. together to be active. The problem I have is when I add T.O.C. to the 6" it #### the T.O.S. Elev. Can some one suggest how to do this. I don' t really want to try and keep two mtext boxes inline when the information could be in one.
thanks Byron
Look at your DIESEL code: the one that works is adding two numbers (10'-7"+0'-6"), the one that does not is trying to add a number to the letters (10'-7"+T.O.C. 0'-6"). You can't do that.
I understand what you are saying, But I am unfamilar with Diesel Code and the help files appears to be limited when you do know Diesel Code. Could you suggest where to go to get information to learn this.
Thank you
