is it possible to tag a multi-view block?
i.e. I have a outlet recept thats a MVB. I have it linked to the space with has the circuit number for the electrical panel. Is it possible to tag a MVB similar to tagging a window?
spaceobjects property set:
spaceobjects:circ_number (manual property set)
also has a location set
recept property set (connected to the MVB of the receptacle):
formula pulls the circ number from the spaceobjects
Solved by jmcintyre. Go to Solution.
Yes it's possible. You can schedule/tag just about anything in ACA. First you have to create a Property Set Definition (PSD) for the MVB objects. In there you can add a location or an anchor property. You can then create a tag to display the required info.
