Attached is a file with a sloping blade wall I have created from a structural member style. The material assigned displays surface hatching in model view, but not in elevation. If I turn on 3D hidden view in elevation the hatching shows and if I change the display rep so that the elevation uses the structural member model view, it works. Is this a bug?
Using ACA2009 sp3.
