AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
summasketch III
5 REPLIES 5
IBHUNTN69
2025 Views, 5 Replies
summasketch III
i get an error when i chose the current pointing device in autocad 2011
Error with the Wintab Compatible Digitizer.
Contact your digitizer vendor for a copy of the Wintab software
any suggestions
5 REPLIES 5
pendean
in reply to: IBHUNTN69
As the error message notes: do you have a WINTAB driver? If yes, what version is it? Where did you get it from?
IBHUNTN69
in reply to: pendean
? not sure if i have one or not. i downladed the tabletworks ver. 10.09 from GTCO Calcomp website & installed the executable file. the 4 button puck works fine in windows but in autocad 2011 when i type tablet @ command prompt it says "your pointing device cannot be used as a tablet.
pendean
IBHUNTN69
it didn't work
cvbt-thailand
Try the driver in this thread:
http://forums.autodesk.com/t5/Pointing-Devices-and-Displays/Summasketch-III-drivers-for-ACAD2008/m-p...
The 10.x series drivers don't recognize regions or scaling.  Ref:
http://www.calcomp.com/supportdigitizing.htm
Please let us know how you make out.
Geoffrey Wheeler
AutoCAD Mechanical 2011 SP2, IV Pro 2011 64bit SP2, stand alone, Design Review 2018, DWG True View 2018, Inventor View // Win7 Ultimate SP1
ASUS P8H61-M LE, Intel i5-3450 @ 3.10 GHz, 8GB RAM // ATI AMD Radeon HD 6600 Series, 1GB RAM
”Boost
