i get an error when i chose the current pointing device in autocad 2011
Error with the Wintab Compatible Digitizer.
Contact your digitizer vendor for a copy of the Wintab software
any suggestions
As the error message notes: do you have a WINTAB driver? If yes, what version is it? Where did you get it from?
? not sure if i have one or not. i downladed the tabletworks ver. 10.09 from GTCO Calcomp website & installed the executable file. the 4 button puck works fine in windows but in autocad 2011 when i type tablet @ command prompt it says "your pointing device cannot be used as a tablet.
Try the driver in this thread:
The 10.x series drivers don't recognize regions or scaling. Ref:
http://www.calcomp.com/supportdigitizing.htm
Please let us know how you make out.
