We've just started using ACA 2012 and have noticed when importing files created in ACA 2009 that structural members do not display properly. We use the structural column or beam to represent a rainwater or soil pipe and are expecting to see a cut through at the cut plane and nothing else however we are getting a couple of lines that represent the crank in the pipe and I cannot turn them off. I'm sure that a setting has been introduced somewhere however after two weeks of looking I am still in the dark. Can anyone help?
I've attached a file created in ACA 2009 that displays the problem in ACA 2012
Many thanks
Ben
I've just opened your file in ACA 2012 and I do not see any structural members.
The soil pipes you mentioned appear to be polylines
Leo,
Thanks for the prompt response, the soil pipes are polylines but the rainwater pipes are not, these are the ones that are causing problems. Being a tad lazy here because the soil pipes are internal there is no need to show them as a solid element.
Ben
Looked at the rain water down pipes, yes you're correct, the cranck and the piece above the cut plain are visible
whilst the actual down pipe is not (plan view)
I've tried but I can figure out why.
(I like your roof edge style with the gutter)
Look at the Display Manager/Represenetations by Objects/Structural Members. The Plan Low Detail has no cut plane component, and it displays the gutter downspout. The other plan configurations all have cut plane components that are all turned off.
kathy,
Thank you for the reply. Unless I missing something the rainwater pipe is on the Medium Detail display rep and not the Low Detail.
Can you expand a little on your response please.
Kind regards
Ben
I noted that you had no overrides checked , so I tried the other OOTB plan display reps just to see if the gutter showed on any other plan rep. I then checked the Diplay Manager to see why it was showing in Low Detail but not the others, which is why I pointed you in that direction.
Kathy,
I don't mean to be "stupid" about this issue but this drawing displays fine in 2009 however when opened in 2012 we get the cut plane at the wrong height (it would appear). What I am looking for is the solution to this and to make the cut plane 1400mm (as per the Medium Detail display rep) but cannot find out how.
Many thanks
Ben
