I ran into a problem with the structural member wizard today. I was making up a bunch of glulams and everything was doing just fine, then all of a sudden the wizard stopped accepting new values for the member depth. No matter what you try to enter, it is rejected and a value of 1'-0" is placed in the field. It will accept new values for both width and lamination depth however. I tried to make a member of another material (steel) just in case it was just the glulams. No luck, they behave the same way, you can't set the beam depth. I also tried restarting ACA, working in a completely new (and clean) file, as well as restarting my computer, it didn't help.
Any ideas? I really don't want to have to go through the repair/reinstall circus if I don't have to.
I guess it's neveremind...for now. I started ACA this morning and everything seems to be working again. I did nothing in the meantime, so apparently it fixed itself. Maybe it was just a twitch or maybe it's a sign of something more serious. Only time will tell.
