Can the breaklines on ACA stairs be moved at all? I have a stair showing with the breakline and I will end up having grating going over part of it. i am wanting to move the break line back so it's not under the grating.
Any ideas, thoughts or comedy relief quotes would be greatly appreciated.
Thank you,
Mike Lamka
Solved by John.W.Mumaw. Go to Solution.
Go to display properties for the stairs, and on the other tab, check the box for "override display configuration cut plane".
John
Thank you. Especially on a Friday, most people have left for the day already.
