AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Space Object Constraints
6 REPLIES 6
75ironhead
734 Views, 6 Replies
New to ACA 2011. What constraints can be used on space objects? I have line work columns and walls in my current project that define the space. is there a way to make a space bound by more then just walls so if I move any thing in the construct the Space plan will update when opened?
I've been trying to find tutorials to explain tools such as spaces with not much luck.
Todd
6 REPLIES 6
JustoAg
in reply to: 75ironhead
Every geometry object (not only AEC) should has a " bound space " property set by default. Spaces created by generating should update (right clic menu) when these geometry change.
Hope this helps.
Justo Aguiar.
75ironhead
in reply to: JustoAg
The space tool is not recognizing my xref as entities when I select it. Do I have to use the space in the floor plan construct?
JustoAg
Xrefs also have the bound space property set to YES by default. Try Space -> Add -> Create -> Generate. It should mark a fine red line in every closed area you cursor move to, picking in it generate a space no matter if it is an Xref as long as it is a closed area.
Justo Aguiar.
75ironhead
When I right clk to "show boundary objects" it only shows the aec walls? All line work or closed poly lines do not show. Even if I create a simple closed polyline it will not generate a space.
JustoAg
You need to set the bound space property of the objects you plan to conform space to YES in the property palette. Then when you invoque the command _AecSpaceShowBoundingObjects It will show you only those who can perform a space object. Make sure your PLINES are really closed (check it in the property palette).
Other than this... I wouldn't know.
Justo Aguiar.
75ironhead
That was it. The Advanced tab was collapsed on the property palette and coming from ADT 2004 there's a LOT of new features I don't know exist yet.
Thank you!!!
Todd
”Boost
