I have been working with ADT 2012 for a month now, and I am missing the way that my crosshairs used to snap to a grid, even if a command is NOT active. If I am zoomed in close, I used to be able to have my pickbox/crosshairs snap to the 1" grid that I have set up. However, that I only works if I have a command like "LINE". What setting do I need to change to make this work the way it has for YEARS? Thanks!
Solved by Matt.Desfosses. Go to Solution.
In SP1 a command was added to get this funtion back. Please make sure you download SP1
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240658
Once you download SP1 the command is
Snapgridlegacy
then set it at: 1
Thanks and let me know if this is what you were looking for.
