AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
slow drag on cad crosshairs
5 REPLIES 5
1311 Views, 5 Replies
I work on a mac and run parallels for autocad. My issue is while working the autocad the crosshairs drag behind my hand movement. when the pointer is moving thru menus it works fine and when i go back to the work space the crosshairs drag behind. Any solutions out there?
5 REPLIES 5
you mean, I have stumped everyone?
Were you able to solve this problem?  We're also experiencing the "drag" on the crosshair.  And we're using a Mac with parallels.  Any thoughts would be helpful.
on command line type 3d config when the box comes up click manual tune then turn off enable hardware acceleration. that should fix it. it did for me.
Unfortunately that one isn't the silver bullet for us.  I'll keep searching...
Peterstair
Thanks for the tip! I am running AutoCAD on a Mac with Parallels.  Your suggestion  seems to have fixed the issue for me.  The only thing now  is that the vertical line in my crosshairs is acting funny. It flickers when it's moved around. Do you have any ideas?
Peter
”Boost
