I am trying to add a hatch to the surface of this slab object (see attached)
Whatever I try I can't achieve this.
Easy enough done to the space object (see attached)
What am I missing?
1. turn on the shrink wrap components of the slab style, both above and below...
2. in you file the hatch components are controlled "by material" so you have to edit the material to control their display
3. In the slab style dialog, edit the "shrinkwrap material" style and turn on the "surface hatch component".
4. in the material style dialog turn on the top and bottom surface hatch placements.
(see the step by step images below)
you are done
regards
aghis
