We have recently migrated to Architecture 2008 and replaced our computer systems which are, unfortunately, running Windows Vista. Most problems we've been able to solve/work around.
Our current problem has to do with opening sheets through the PN. If nothing else is open, a sheet drawing will open fine. But, only one sheet drawing will open. If you open a view drawing, you can open as many as you like and everything seems to work fine, except with a view drawing open, you can't open any of the sheet drawings. If you close all the view drawings, you can once again open one sheet drawing.
Is this an Autocad setting or is it a Vista compatibility problem?
I would appreciate any assistance.
Craig
