AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Sill of Opening not showing
1 REPLY 1
BBP-Arch
336 Views, 1 Reply
ACA11
I inserted a half-round opening into a wall. the cut plane is set to about a 1/2" above the sill of the opening. The wall has only one component. "Hide Objects Below Cut Plan" has been unchecked. "Display Inner Lines Below" has been checked. All layers are on and thawed. I see the opening in plan. I've checked and it's the right height, etc. No sill lines. I thought openings could have sill lines... Where is my boo-boo?
Scott.
1 REPLY 1
BBP-Arch
in reply to: BBP-Arch
Sorry, I figured it out. Besides having a loose nut behind the wheel, I missed a display component being off...
Cheers.
”Boost
