ACA11
I inserted a half-round opening into a wall. the cut plane is set to about a 1/2" above the sill of the opening. The wall has only one component. "Hide Objects Below Cut Plan" has been unchecked. "Display Inner Lines Below" has been checked. All layers are on and thawed. I see the opening in plan. I've checked and it's the right height, etc. No sill lines. I thought openings could have sill lines... Where is my boo-boo?
Scott.
Sorry, I figured it out. Besides having a loose nut behind the wheel, I missed a display component being off...
Cheers.
