Hi all, I have a question about
sheet name field, can it be broken into 2 or 3 lines?
Our office has huge text size for drawing name,
which can not be changed to a smaller one (you know
the politic craps about standards).
So I wonder if there is a way to break the Sheetname field to
2,3 or 4 lines to accommodate this. So far the field is set to
have one single line at best. It was good for
"floor plan" but not good for "floor plan and etc, etc...."
I am afraid that sheet set field cannot be broken into two lines as of now. I case if you feel this could be a useful enhancement you may provide you feedback on the link below:
Well, I beg to differ with product support....
If you create your field with mtext, and you set the width of your mtext box to whatever you need, the contents of the field will wrap to however many lines is needed. This is only limited to how many caracters ACA will allow you for a sheet tiltle (or any other field for that matter) You can justify the field as you would for any mtext, right, left, center, fit etc.
If you create the field with dtext, it will be a single line and will not wrap the contents.
