AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Sheet List Table - Deleting Rows
11 REPLIES 11
Message 1 of 12
4125 Views, 11 Replies
How does one delete rows from sheet list tables generated with Autocad 2009?
That function is grayed out and non-operable for sheet list tables we generate with Autocad 2009.
However, that function is OPERABLE for sheet list tables we generate with Autocad 2007 (We CAN delete the rows and/or contents)
We are selecting the actual entire row in the 2009 sheet list table.
All the data in the rows is unlocked.
We CAN delete the contents from the rows, but not the actual rows.
We CANNOT clip the table, so the empty rows are still visible.
The sheet list table has 300 sheets listed, so it has to be modified to fit on the cover sheet.
Annoying.
11 REPLIES 11
Message 2 of 12
I have the same problem on autocad 2015, but it looks like nobody can solve this problem since jimdlord posted it back in 2009. Anyone has any solutions on  this problem?
Message 3 of 12
VitalyF
This is no problem for me >>
You can attach an example to help you better?
Vitaly
Message 4 of 12
VitalyF
This is a real the Sheet List Smiley Happy
Vitaly
Message 5 of 12
mgalicki
in reply to: VitalyF
UH! What release is this from? And I can't see what you're doing when your curser goes down out of the video? I'm running 2014 & you can't select a cell, row or column to delete it. Right click gives me the table properties dialog box.
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
Message 6 of 12
VitalyF
in reply to: mgalicki
This is an old feature, if not mistaken
I just pick a table
PS
This MEP 2016
Vitaly
Message 7 of 12
mgalicki
Thanks Vitaly, I since then can now update my table that was generated from the Sheet Set.
I right click the sheet set & pick "Insert sheet list table"
How ever now I've renamed a few files and re organized files under subsets  (thru the SSM).
My first subset now only puts the first of 5 files in the table when I "updated it?
Strange?
Autodesk MEP 2019
Message 8 of 12
VitalyF
@mgalicki
Your sheet sets has been regenerated after renaming?
Message 9 of 12
mgalicki
Thank you for the reply!
regenerated? I did do a Resave all. I've also tried adding a new sheet & do an "Insert Sheet List Table" but this causes autocad to crash?
Are you only allowed (1) sheet list table in the sheet set?
Autodesk MEP 2019
Message 10 of 12
VitalyF
Yes only (1) sheet list table allowed  in the sheet set!
You can remove it and replace with a new.
Message 11 of 12
mgalicki
My problem has been corrected!
Apparently Plant 3D doesn't like (some) Sheet Sets commands.
Insert Sheet List is one of them.
I was able to get it all working perfectly when running the Vanilla AutoCAD!
Getting ready to upgrade Plant 3D from 2014 to 2016!!
I hope some of these issues have been incorporated & fixed ??
Thanks for all your help VitalyF.
Have a great weekend!
Mark
Autodesk MEP 2019
Message 12 of 12
Norton72
Thank you!
”Boost
