Hi everyone!
How to make shadows on the print in Viewport?
You can see the result I would to achieve on the PIC.1 and PIC.2.
I have done just PIC.3 - there are not shadows.
I was using Visual Style on the PIC.4 in Shadow Plot setting in properties of Viewport.
How to goal shadows? Im using AutoCAD Architecture 2013
Thank you.
PIC.1
PIC.2
PIC.3
PIC.4
Solved by KathyMoffa. Go to Solution.
Go to the Render tab, turn the sun on and/or add a light, turn off default lighting and change No shadows to Full or Ground (try both to see the difference).
