AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Settings to allow a block to be trimmed, etc..
3 REPLIES 3
octavio2
1118 Views, 3 Replies
Can blocks be trimmed with the trim command, etc?
If so, where are the settings to allow this?
Thanks in advance.
3 REPLIES 3
David_W_Koch
in reply to: octavio2
The AutoCAD TRIM command will not work on block references.  You can achieve the equivalent by using the AEC Trim tool (AecLineworkTrim command).  You can read more about this command in the Help or in this blog article.  Note that only "trimmable" objects within the block definition will be trimmed; any non-trimmable objects will be left as is.  Per the Help, hatches, polylines, circles, arcs, spaces, AEC polygons and mass element extrusions can be trimmed.  Lines work, also.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
pkolarik
In addition to what David mentioned, you can try clipping your blocks using the "xclip" command.
Victoria.Studley
Hi Octavio,
Did David's post help you accomplish what you're trying to do?
That blog article is a great resource, and covers the same concept as the following help article, in a bit more detail.
To Trip Linework or Profile-Based Objects
Let us know if you need more clarification. Post a file, if you're trying to do something specific, and would like further assistance.
Victoria Studley
Content Experience Designer - Fusion 360
Fusion 360 | Learn & Support
Documentation | Contact Support
”Boost
