Are the values shown in the Schedule Table the correct Imperial numeric values, but expressed in Metric units, or are they the equivalent Metric measure for the assigned Imperial measure. (In other words, is a 3'-0" wide door being reported as 36 mm or as 914.4 mm?)
Is the Schedule Table in the same file as the Doors? If not, do you have a different template assigned for the creation of View files or Sheet files from that assigned for Elements/Constructs? If so, could that template file still be set up for Metric?
If that is not it, from where are you pulling the Schedule Table - an Imperial or Metric source? What Property Data Format is assigned to the columns that are reporting Metric Data?
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
