AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Schedule Tag only an attrib def access property set data... hooked leader
1 REPLY 1
mdhutchinson
278 Views, 1 Reply
I've fashioned a Schedule Tag with a leader... currently the attrib definition is Left justified. At the left end of the attribute, the block also has a short horizontal line to act as the 'hook' on a leader.
This works well to click and drag the leader from left to right... but might there be a trick to allow this to also work from right to left and have the hook and leader attach at the right end of the attribute?... or will I need to do a second version of this for use from right to left?
Also, can someone refresh my memory as to why the Schedule Tag block attributes are set up to be 1 unit tall in the block definition?
1 REPLY 1
in reply to: mdhutchinson
1 unit tall means that the annotation size and annotation scale settings
can both be used to determine the text/tag height.
wrote in message news:6305787@discussion.autodesk.com...
”Boost
