I have a door and a window schedule in my Model. The Model file is referenced in a View File. The door schedule shows up, but the window schedule is showing only with the Title - the whole schedule is missing. I've checked everthing from object overrrides to the display to the layers being off, but cannot get the window schedule to show up in the View drawing. What else could be causing this?
One of the possible reasons could be the layer wildcard filter. Select the schedule table and in the properties palette, check if the filter value of 'Layer Wildcard' is correct.
It is possible that the schedule is reading the construct as well as the view drawing.
I have always found is easiest to place the schedule(s) in it's own view drawing and let it "scan" the xrefs you want the schedule(s) to read.
This makes it easy to have schedules for different floor levels in one file.
