I have some trouble with scale in general.
I have a drawing set to units in Meters, with some plans and elevations of a building.
The building is roughly 10-12 meters in length, and when I measure it with the measure tool for example the 3 meter wall I made shows "3.00" as the number, so it's 1:1.
When I create a layout, and I set it in the manager to be ISO A1 sheet size, I then proceed to create a viewport and I want to fit 4 elevations into a 1:50 scale, meaning that each elevation should show the building as a 24x20~ cm area on the A1 paper.
When I click the scale of 1:50, the viewport zooms in A LOT, meaning that the elevations don't even fit on the A1 paper...
A1 is about 60x80 cm in size, so this is really wierd.
Also, and this might be connected - a lot of times when I write text or a leader etc., the text is HUGE, and I always seem to do something right by chance when I try to fix it to a normal size, but I can't really understand the root of the settings to put there so that it won't keep happening... There are about 3-4 places where annotation scales etc. are options in the program and when you don't know which one to choose you get errors in text scale... I'd appriciate some basic tips about this if anyone knows.
Thanks in advance and I hope you can help me out here.
Hope it helps
aghis
