AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Rotate a building in UCS to WCS coordinate
2 REPLIES 2
antigonos.2
1265 Views, 2 Replies
I have a lot of caddrawings of buildings that are drawing using a UCS (User Coordinate System) there up is up, left is left..
The problem is that i want to rotate the WCS (world Coordinate System) there so it match the UCS, but rotate of the WCS cant be done.
So I want to rotate all drawings so that they WCS looks like they do in UCS today
The reason why I want to do this is that the dataextraction function is using the WCS coordinate system and i have to transform the drawing, so the result become the same if it have a option to use UCS.
Can anyone see a easy way to do this?
//Kalle
2 REPLIES 2
dbroad
in reply to: antigonos.2
Perhaps if you post a sample showing your problem..  I couldn't follow your description of your UCS.
Depending on the complexity of your drawing, one technique that might work:  Make your UCS current.  CTRL+X in model space and select all objects.  Change to WCS.  Pasteorig and it should move the objects to your desired orientation.
Architect, Registered NC, VA, SC, & GA.
antigonos.2
in reply to: dbroad
Hi Thank you for your suggestion. But it didint work and i think i have too many objects to my  Autocad architecture 2011.
The problems is that i cant copy so many object. if a one copy a few lines it work fine.
Here is a sample of a drawing. My problem is as I said in my last post that I will do a dataextraction of the drawing and the result would be that the UCS was the WCS. The importent things is the angles, x and y position of the hole building is not importent.
And i should do a explode all before the dataextraction to make simple cadobjects. If i do the explode before or after rotation is the same for me.
The problem is that i have a lot of cad drawings and the people who should do the cadjobb is not people with cad experience. (so i should do i easy guide, maeby record, lisp, vba or something)
The solution i have now is use Dview, then Twist and try and get a good angle. Then do this for all buildings on one house, the problem is that i have a lot of houses and the work should be done during a longer period.
//Kalle
”Boost
