ATTSYNC doesn't work with MVblocks.
If you need to change the justification of the the text in the tag, open the
block in the Block Editor, change the text justification to whatever you
want
and save. From memory, existing blocks with not update, you will have to
retag.
Leo
"Anthony Mason" < wrote in message
news:5832188@discussion.autodesk.com...
Use the ATTSYNC command after redefining your block. I'm not sure if that
works on Multi-View blocks though.
As for making it read "0011", go to Style Manager - Documentation Objects -
Property Data Formats - Number-Object, and change the Zero Padding to 4.
"Eric" wrote in message
news:5831970@discussion.autodesk.com...
The Aec Room Tag Basic P tag has the text inside the box to Fit and we want
to edit the text. Where do I edit that? I tried inserting the block and
exploding and redefining and weird things happen. The boxes get larger and
the room tages already in the dwg do no update. Any help is appreciated.
Eric
