Our firm is starting our first project in autocad architecture but we are running into problems here and there. I have set up a new project in the project navigator with two floors; one at -8'7" and one at 0',0". I have applied room spaces to both floors, but when I xref one model into the other from the project navigator, the spaces in the active model intersect with the spaces from the xref model. I have verified that the spaces do not extend past their own levels, so I am not sure what the problem is. Attached is the lower level, upper level, and the upper level after the lower level has been xref'd.
Thank you,
Alex
I cannot really tell what is going on from screen captures, but it appears that your upper level Spaces are "finding" some of the Walls from the lower level, which are then acting as room-bounding elements. Check your upper level Spaces and see if the height below floor is set to something greater than 0. If so, the tops of the lower-level Walls may intersect the Space volume, causing them to be used as room boundaries in the combined file.
