All,
I have been (for a while) searching for a solution to the display of roof windows on plan in AutoCAD Architecture. Currently there is no way of anchoring the window to the roof simply align it and create a subtracted interference condition. I then have a style that turns off the window sill on plan. This is a good solution until I turn the roof off in a viewport and then all evidence of it disappears on the plan. I have been using a dashed rectangle to represent the display of the roof light which is a good solution however is there anyway to apply a parametric block to the window style so that when the size changes the rectangle changes and this is always visible on plan even when the roof layer is turned off?
Many thanks
Ben
You can apply a custom block to the window in whatever display configuration you desire and make it scale to height/width. Go to the "Other" tab of the Plan display representation.
Libbya,
Thank you for the reponse. I've done this on the attached drawing in ACA 2010 however I am trying to get the plan image to match the window when it's rotated at different angles.
Can you advise?
Kind regards
Ben
I have not yet used skylights, but it is an interesting issue. In playing with your file, adding a block to the plan display config is not the approach I'd take. Depending on the level of detail required, I would probably use a dedicated roof slab and place it on the window layer and adjust the display as necessary. If the added detail is necessary, another approach you could use is to use the Display Manager to turn on the Model Dispay Representation in the Plan display Set. With turning that on, tho, you will need to turn off all of the individual display items for the Model Rep for all the other window styles in the drawing.
Hi Ben
Libbya's IMHO response is the correct one but perhaps you need to get the settings right and also drawn the block to be inserted in elevation view not plan view.
The other items is to set the inserted block onto an annotation layer so when the roof layer is turned off, the block remains on. Once it displays correctly, turn everything else off (don't forget sill view).
attached in version ACA2013
Nathan,
Thank you for the post. Can you save the file back to 2010 please. I'm up to date on software but haven't installed them yet.
Regards
Ben
Doh!! Of course it can't. I knew that.
I'm not sure I've explained this correctly, the problem occurs when we change the pitch of the roof and then the pitch of the window in it. In the attached drawing I've got a window set at the same pitch as the roof and on plan the outline you can see it the hole in the roof (interference condition). If I now change the pitch of the roof and the window but turn the roof off in paperspace I loose the outline of the window. So it's not really a size thing more a footprint depending on the angle of the window. It is this we want to see.
What it really needs is a proper roof light to be introduced to ACA. Autodesk?
Regards
Ben
