AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
RIBBON TABS NO LONGER VISIBLE
3 REPLIES 3
1927 Views, 3 Replies
PROBLEM IN AUTOCAD ARCHITECTURE 2013,
THE INCERT, ANNOTATE, LAYOUT, PARAMETRIC, VIEW, MANAGE, OUTPUT, & ONLINE RIBBON TABS IN THE DRAFTING & ANNOTATION PROFILE DRAWING ENVIROMENT ARE NO LONGER SHOWING. ONLY THE HOME TAB IS DISPLAYED. THEIR DISAPPEARANCE SEEMED TO CORRESPOND WITH A FORCED SHUT DOWN DUE TO A LOCKUP OF THE PROGRAM AFTER TRYING MY FIRST HYPERLINK. ALL DEFAULT TABS ARE SHOWING IN ALL OTHER DRAWING PROFILES (3D BASIC, 3D MODELING, AUTOCAD CLASIC, AND ARCHITECTURE).
HELP
chipfancher@comcast.net
3 REPLIES 3
MarySeufert
Try "Reseting Settings to Default" located under Windows Start Menu->Programs->Autodesk->AutoCAD Architecture 2013. Warning, any customization to the CUI willl be removed. You can also do this from within ACA. Under CUI, Customize tab Right-pick the ACA main node and select "Restore ACA.CUIX".
~ Mary
EXPERT ELITE MEMBER
in reply to: MarySeufert
Worked. Thanks Mary
bzeone
Does this reset all the settings in AutoCad or just related to Ribbons?
”Boost
