Howdy:
Although we're in Architecture 2012, I've gotten rid of the Windows ribbons and used MENULOAD to bring back the toolbars I am most efficient with. Using the revision cloud button on the DRAW toolbar, I draw the clouds in paperspace like I always have. The arcs of my clouds now flip back and forth so that they are sometimes correct and sometimes inside out. I don't know when this started (with the upgrade to 2012? out of the blue?), but it's been going on for a while and it happens whether I draw clouds clock-wise or counter clock-wise.
There used to be an option where you could "flip" the cloud to change the arc "direction" and now it seems to do it automatically. No matter how slowly I draw a cloud, I often end up having to erase and redraw (and redraw, and redraw). I've searched Help, but I can't find any mention of changing the orientation or direction of the arcs on a revision cloud.
Is this a feature, a setting or a bug in my system and is there any way to make it go away?
Thanks.
It's been there for quite a while and is easily triggered when you drag-to-draw the cloud: very difficult to control of your arcs are small and you need to go back on yourself as you draw it.
Unless someone has a better idea, I find using REVCLOUD's OBJECT option to cconvert a drawn polygon/rectangle to a cloud shaped the best method with the best final control.
I think the best way is to finish your revision cloud a little bit higher than you started it. Then, it will clode in the good way. If you finish it lower than your starting point, it will close inside out.
aww....your day is cloudy in so many ways.
I gave up freehand Revclouds when I realised you could just slap a Polyline around everything and convert it. It even asks you if you want to reverse it or not. Can't remember if 2012 did that or not.
I found out that the direction of cloud drawing matters. When points are specified counterclockwise the cloud is automatically flipped inside-out. When I draw it clockwise it appears normal.
