AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
REVISION CLOUD AND TAG
2 REPLIES 2
jmartinarch
364 Views, 2 Replies
ACAD Architecture 2011, Win 7 64
In paper space I am placing a revision cloud (works fine) then the tag comes in HUGE.  I placed it and checked the scale and its scale is .125 and the  annotative scale is 1:40.  I  suspect this is the problem.
I entered 'units' on command line. Units set to inches, type: architectural.  Scale: 1:40.  I don't know why it is 1:40.
It is an architectural floor plan with scales of 1/4" and 1/8".  So I changed the scale to 1:1 (since I was putting clouds and tags in paper space), 'apply', enter.
I type the units command again and it is back to 1:40.
How do I fix this.
2 REPLIES 2
pendean
in reply to: jmartinarch
You working in a metric file by chance?
jmartinarch
I don't believe so.  Units are inches, type: architectural, precision: 1/16"
How would I check?
”Boost
