I am using AutoCAD Architecture 2010
Everytime I open a session of AutoCAD, I must select my profile.
Is there a setting that would retain my profile as current?
How are you starting ACA? If you start from a desktop shortcut, you can specify that your profile be set current in the Target string on the Shortcut tab of the shortcut's properties. The /p switch preceeds the profile specification. If you have exported your profile to an external ARG file, you can specify that file, including the path to it. Enclose the path/file name in double quotation marks if there are spaces in the path or file name.
