how big is your file?
Windows 32bit has issues. Autocad doesn't have much to complete the task.
When you have it all set up and you are happy, save and close autocad and
restart.
Then render and you may get thru.
You can also increase the memory in the renderpreferences RPref box down the
bottom (providing you have more to assign).
1024 >>>
You should have 4Mb RAM max in 32bit to be as comfortable as you can be.
Were you not having these issues in 08?
<1bdchristian> wrote in message news:6277857@discussion.autodesk.com...
We have just recently upgraded from 2008 architecure to 2010 architecture. I
was wondering if anyone else was having a problem rendering. When I attempt
to render I get a dialog that says "Autocad is running our of system memory"
