When I go to render my project, the windows that are set to a glass finish are a solid yellow color. How do I change this to make the window transparent to the inside when I render? I've attatched a picture of the issue.
Check that there is a render material set in the aecmaterial definition of the glass style.
Then check the render material using the MAT command.
You could just reinsert a new glass material and switch to that.
